Justin Posted August 5, 2008 Report Share Posted August 5, 2008 1/4 inch, damn. Have you already tried adjusting the latch on the hood and in the truck? Or even (yikes) using smaller bolts so you can adjust the hood more? Those replacement parts always need a little "massaging" it seems like- Good luck with the fender! Quote Link to comment
Fuelrags Posted August 6, 2008 Author Report Share Posted August 6, 2008 As far as the center support goes...I am a big fan of getting a one piece shaft made. After calling around a ton when mine went south...i found that they could build me a sweet looking 1 piece for less than the work i needed done on mine. I was getting the shaft balanced too...after I had shortened it for the 5 speed conversion...but still..worth looking into. Better stop light action too..since there is no more sloppy driveline. Just a thought. Lowering the truck will actually help in this case, because it alignes the trans output and the rear diff better. How much did it cost for the 1 piece may I ask? Quote Link to comment
Fuelrags Posted August 6, 2008 Author Report Share Posted August 6, 2008 1/4 inch, damn. Have you already tried adjusting the latch on the hood and in the truck? Or even (yikes) using smaller bolts so you can adjust the hood more? Those replacement parts always need a little "massaging" it seems like- Good luck with the fender! Massaging?!...(I hope I get a happy ending:cool:) Quote Link to comment
