510T Posted April 28, 2013 Report Share Posted April 28, 2013 Ratsun: I have a pair of S12 200sx 4 lug struts for sale. They have been shortened, fitted with DPR steel coilover sleeves and powder coated semi gloss black. The struts will include the lower spring perches. The hubs and rotors are currently installed and included. All the hub bearings and seals were replaced roughly 2 years ago and hubs were painted. One rotor has 2 small cracks in the outer face. I am willing to separate the rotors due to the cracks, but am more than happy to leave them ;) I also have the matching calipers available but they will be sold as cores, the slide pin boots are torn up. Calipers come with mounting bolts and Porterfield R4-S pads with quite a bit of meat left. I will include 8 lugnuts of either acorn or shank style and the gland nuts will be included to prevent damage to the top of the tubes. The gland nuts are a little chewed up. Reason for sale is I upgraded and no longer will need these. These struts are designed for positive offset wheels with bigger backspacing than ZX struts. They also have a 54mm steering arm hole, you will need special RCA's. Please do your due diligence with regards to fitment before buying. Struts, hubs, rotors $200 + shipping Calipers + pads $50 + Shipping Complete package with struts, hubs, calipers and rotors $240 + shipping Just Struts and Hubs $220 + shipping The Panasports are in very nice shape. Maype a couple nicks and some very minor curbing (from a previous owner ;) ). Pictures illustrate fitment on my 510 with the above struts and corrected rear camber. I had the hub bores of these wheels professionally machined to fit on Nissan hubs, and at the same time had new lug inserts installed. Tires will be included, all 4 low mileage 175/70R13. 1 tire has been plugged but holds air just fine. $600 + shipping Thanks for looking :) Link to comment
skyblue Posted April 28, 2013 Report Share Posted April 28, 2013 Are these bolt on for 510s? 1 Link to comment
Laecaon Posted April 28, 2013 Report Share Posted April 28, 2013 Are these bolt on for 510s? Yes they bolt in. No, they dont pull in the wheel like 280ZX. These are a great option to run. 1 Link to comment
510T Posted April 28, 2013 Author Report Share Posted April 28, 2013 Also thought I would add that these will clear some 13" wheels. My 13x7 Panasports fit great. Link to comment
510T Posted May 4, 2013 Author Report Share Posted May 4, 2013 Bump for Panasports :thumbup: Link to comment
