70RUSTY510 Posted April 8, 2013 Report Share Posted April 8, 2013 Hey guys i have a question, is there suppose to be a hinge that holds up the glove box lid when is down? whenever i open mine it just falls out and hangs by the arm on the side. can someone post a pic of their glovebox down so i can see what i need to look for please :) I have a 1970 datsun 510 Quote Link to comment
Ratwagon1600 Posted April 8, 2013 Report Share Posted April 8, 2013 Hmmm, reasonable request, therefore, for your viewing pleasure: At least you don't ask for info on a KA swap :) Quick post edit, if you want a pic of the hinge (having Reread your post I think that's what you may want?) I'll take another photo. 1 Quote Link to comment
70RUSTY510 Posted April 8, 2013 Author Report Share Posted April 8, 2013 thanks Ratwagon1600 :), sorry if i wasnt clear enough. My glovebox lid has that small hinge arm but i'm trying to see how the lid is held by when its down like that. Is there another hinge? I need a top view of the lid down like that please lol :) Quote Link to comment
Ratwagon1600 Posted April 9, 2013 Report Share Posted April 9, 2013 Its almost midday here. Ill be home in about 4 hours and will post more pics for you then. Cheers Quote Link to comment
DatWifey Posted April 9, 2013 Report Share Posted April 9, 2013 There's no additional hinge, it's just the one piece that is seen in Ratwagon's. Here is a view of it from behind When it's closed And when it's open, the small bent tab holds the door from falling all the way down Quote Link to comment
70RUSTY510 Posted April 9, 2013 Author Report Share Posted April 9, 2013 @DatWifey ah i see ok, i have that hinge arm but when i pull mine down it basically hangs but doesnt hang flat when opened. Quote Link to comment
nismosilvia Posted April 9, 2013 Report Share Posted April 9, 2013 There's a write up in the how too for fixing the hinge Quote Link to comment
Ratwagon1600 Posted April 9, 2013 Report Share Posted April 9, 2013 Ok, better late than never. First up, the glovebox assembly is held in by 12 Phillips head screws like these: First step (obviously is to remove the screws). Remove the complete glovebox assembly and turn it over and you'll see the following: Next step is to undo the three 8mm nuts which hold the lower glovebox trim on: You should now see three Phillips head screws with speed clips which connect the lid to the glovebox assembly: Undo these and you end up with this: Obviously the above presupposes you have a fairly original glovebox. The hinge assembly on the lid is prone to shearing off and fixes range from 100mph tape (we also call it Gaffa or Duct tape) or custom fabbing a hinge assembly from a light gauge pliable plastic. Anyway, enough from me, hopefully this gives you a better idea. Cheers Jason Quote Link to comment
70RUSTY510 Posted April 9, 2013 Author Report Share Posted April 9, 2013 @Jason thank you very much for the writeup now I know the problem with mine.... The plastic hinge is broken from the glovebox :/. Quote Link to comment
Ratwagon1600 Posted April 9, 2013 Report Share Posted April 9, 2013 All good mate, happy to try and help and besides, you gave me an excuse to pull my glovebox out to fix a crack in the frame :) Can provide you with more measurements if needed, but, with my two cents worth, and Nismosilvias post about the hinge fix (I'll go searching for this), you should be headed in the right direction for a decent fix. Quote Link to comment
70RUSTY510 Posted April 9, 2013 Author Report Share Posted April 9, 2013 Yup I am in the right direction lol I have a hinge that should work needs a little modifying but will do the job. Quote Link to comment
Laecaon Posted April 9, 2013 Report Share Posted April 9, 2013 some ideas http://community.ratsun.net/topic/17173-how-to-repair-a-620-glove-box-door/ Quote Link to comment
