DATSTON Posted April 7, 2013 Report Share Posted April 7, 2013 I left my 620 sitting for a few weeks and found out the cabin light was left on. Tried to jump it, but the motor won't even crank over. Any ideas? I'm thinking about replacing the battery, but even if the battery was bad a jump should still work right. Quote Link to comment
racerx Posted April 7, 2013 Report Share Posted April 7, 2013 If you have a trikle chargr, charge it overnight and see what happens, if not take it to your local Oreilly's or autozone and they can check it for you. Quote Link to comment
crackerjack69 Posted April 7, 2013 Report Share Posted April 7, 2013 Put a known good battery in the truck and see what happens. Quote Link to comment
Jayden71 Posted April 7, 2013 Report Share Posted April 7, 2013 Leave the cables hooked up for a few minutes before trying to start Quote Link to comment
datzenmike Posted April 7, 2013 Report Share Posted April 7, 2013 I left my 620 sitting for a few weeks and found out the cabin light was left on. Tried to jump it, but the motor won't even crank over. Any ideas? I'm thinking about replacing the battery, but even if the battery was bad a jump should still work right. It should crank over with a jump. So maybe it isn't dead just a loose connection. Check the neg cable is tight on the head and the pos on the starter. Try honking the horn. Quote Link to comment
John1990 Posted April 16, 2013 Report Share Posted April 16, 2013 It's most likely ur battary after a battary is dead for a certain length of time the battary cells will go bad and no longer take a charge nor take a jump Quote Link to comment
