EricJB Posted April 6, 2013 Report Share Posted April 6, 2013 Which header do you guys prefer and why? The plan is L28 shortblock, ballanced rotating assy / 72 E88 mild port with 44mm intake and 37.5 exhaust / Isky 490/290 cam and apropriate hardware / Triple 40DCOE's. Any ideas for complete exhaust appreciated. Quote Link to comment
Dawa Posted April 6, 2013 Report Share Posted April 6, 2013 according to this book street exhaust mild street: for any stock or slightly modified engine, the original equipment exh mani is suitable. but to improve performance, the exh pipe & muffler should be replaced...a 2.5" pipe works best w a 6 cyl engine. the most popular performance muffler is the reverse flow corvair type thats available from most perf. exh sys manufactuers... commonly called turbo mufflers... this muffler type is free flowing, relatively compact & reasonably light. for 6 cyls, muffler inlet & outlet size should be increased to 2.5" the pipe should not neck down inside the muffler. wild street if youve modified your street eng, a good exh header will enhance eng perf.a radical street perf. eng should have characteristics similar to those of an off road racing eng. more attention should be paid to obtaining bottom end low rpm tq & a wide power band than obtaining max HP, which can only be gained at high rpm. this this in mind, most street perf engs should have 1.5 or 1 5/8" dia primary pipes 34-36" long. which dia you should use depends on your engs power band, max rpm & displacement.as an example... 2800cc with many high perf mods may need 1 5/8 primary pipes w a 2.5" collector & exh pipe for max perf. sixes should use two collectors. number 1,2, and 3 primaries go into one collector and 4, 5, and 6 primaries go into another. the two collectors are then connected by the y-pipe" Quote Link to comment
EricJB Posted April 6, 2013 Author Report Share Posted April 6, 2013 Thanks, I have that book somewhere, cant find it. Wondering if anyone has a similar set up and what they run. MSA header looks like crap. Arizona Z car has shit collector but people seem to like them. Stahl is really nice but $910.00 Clifford stopped making them. I think Holley bowed out as well. Seems to me that a 6 to 2 to 1 (tri Y)would be the best way to go. Dont know. I cringe at the thought of making one. The one I made for my 521 was Hell. Quote Link to comment
craprat260 Posted April 7, 2013 Report Share Posted April 7, 2013 I got a msa ceramic 6-1. Love it and love the sound. Installed it in my garage but one thing is the msa 6-1 doesn't have too much ground clearence. the 6-2 cuts off earlier so you can just fab something up that will clear. I had to raise my car because i couldn't get up my driveway. but the 6-1 was definetly hassle free to install and the ceramic's held up pretty well so far. Quote Link to comment
Interrobang Posted April 8, 2013 Report Share Posted April 8, 2013 6-2 MSA does mate up perfectly to their twice pipes exhaust... Was considering this set up. Cheap, sounds good. Quote Link to comment
ArchetypeDatsun Posted April 9, 2013 Report Share Posted April 9, 2013 The twice pipes sounds awesome in a Z seen a few S30's with them and they sound real nice. I'm tryin do either 6-2 header or 6-1 header on my 810 goon once I get funds. Quote Link to comment
JonU Posted April 10, 2013 Report Share Posted April 10, 2013 No idea how it's going to sound but I have a 240 that's being painted atm. Once it goes back together it will have a 6-2 MSA header running a dual exhaust w/ X over all the way to the rear. Hopefully I'll have a few more pieces to go on it as well, but for now that is all I have. Quote Link to comment
EricJB Posted April 12, 2013 Author Report Share Posted April 12, 2013 So of the cheaper headers available ( most of the $$$ really well designed ones seem to be NLA) It appears the Arizona header and Pacesetter are the only 2 that even make an attempt to build a tuned header. All others look like #1 cylinder is 6" longer that #3. The Arizona is 6 to1, and Pacesetter 6 to 2. I have ran Pacesetter before and not been impressed. But the collecters look way better than the Arizona. Pacesetter Arizona I hate to say it, but i'm leaning towards Pacesetter. Quote Link to comment
