Dawa Posted March 31, 2013 Report Share Posted March 31, 2013 this is the last piece to convert my 73 620 to disc brakes using beebani's UCAs, etcshould look like this: http://www.ebay.com/itm/DATSUN-Pickup-Truck-520-521-620-720-1965-1986-Spindle-Upper-Arm-/221066537235?pt=Vintage_Car_Truck_Parts_Accessories&hash=item337897a913&vxp=mtr#shId ^ has them for $23 each (new, aftermarket [taiwanese]) plus about $22 shipped for a total of $68 shipped i would just go that route except it says itll take about a month to get here, idk if ill still be at this address in a month.... so i need those parts, new or used. if used, intact threads and in good shape, please. PM me or reply, i check ratsun @ least once a day. Link to comment
jesusno2 Posted March 31, 2013 Report Share Posted March 31, 2013 I will tell ya right now that the 720 cross shafts have 14mm holes, I dunno if the 620 is anything like the 521 but it uses 12mm bolts just so ya know ya might end up being WTF why are the holes sloppy. Link to comment
wayno Posted March 31, 2013 Report Share Posted March 31, 2013 I would suggest that the upper control arm mount holes be drilled and tapped out to the 720 bolt threads, not doing that is one of the biggest mistakes I made on my 521 disc brake conversion. Take my word for it, when I say you do not want them wimpy bolts braking on you like they have on me several times, it's real eye opening when they break, especially when you are moving at 30mph and the frontend drops out from under you, I would hate to think what would happen if it happens at hiway speeds just because you touched the brakes, not slamming on the brakes, just touching them, that's what happened to me once going 30mph, all the other times I was going less than 15mph, but it sucks none the less. Link to comment
Dawa Posted March 31, 2013 Author Report Share Posted March 31, 2013 thank you both. different mounting bolt sizes is something i didnt catch, because i dont think it is mentioned too often. i had considered the two options were to make a filler/spacer with some cut pipe, OR drill/tap but now i know ill definitely be going with the second option. thanks guys. Link to comment
Dawa Posted March 31, 2013 Author Report Share Posted March 31, 2013 found 2 sets.one from a 79, the other from an 85. largest socket i had was 21mm so couldnt pull it today. hopefully one or both sets will be there by the time i go back. Link to comment
jesusno2 Posted March 31, 2013 Report Share Posted March 31, 2013 14mm bolts would be a 22mm socket. 12mm bolts 19mm pretty sure. Link to comment
Dawa Posted March 31, 2013 Author Report Share Posted March 31, 2013 yeah i figured it was 22mm since the 21 "almost" fit, but didnt want to make a mistake and let someone have the chance of correcting me, aha. thanks again yall Link to comment
