anyone succesfully use su's with oem airbox on 620?
Ricky116
Ive been thinking about this forever. I have su's on my L18 in my 78 kingcab and I want to use an oem airbox but the booster is totally in the way so I have a early (73 I think) brake booster that is much smaller but theres still not enough room. Im thinking, well I can put smaller insulators in between the manifold and carbs but still need more room any suggestions or info on this? Thanks in advance Ricky
  • Replies 5
You will likely have to fabricate something like the 720 diesel engine filter assembly, or use 2 small flat/low profile filters.
I am using the OEM airbox(likely from a 510), that has been modified(made smaller), but I don't have a power brake booster in my 521 either.
What are you using now?
