Flext plate to TC bolt torque
izzo
Anyone know what the proper torque is for the flex plate to the torque converter? There's four bolts that connect it. I searched the book but wasn't able to find the torque specs. I don't mean the flex plate to crank. Already found those ones.  Thanks!
  • Replies 8
I got the flex plate to crank bolts spec'd right. But the bolts that go on the flex plate into the torque converter, I can't find those. Just skimmed thru the link.  Didn't see them?? It didn't take to much to get the four bolts off...
I usually just go tight as you feel comfortablewith,,, with box end then rap them with rubber hammer ,, they are pretty big bolts so probably wont break to easy..
the manual i have says,,, Torque convertor housing bolts to 32ft lbs. Tighten drive plate to convertor bolts to 28ft lbs.
Not sure what the differance is.. ??
