riot936 Posted March 23, 2013 Report Share Posted March 23, 2013 While getting my 720 4x4 leafs from the boneyard I quite literally stumbled upon a center console with factory gauges and the center armrest part as well. NOW, how would I wire the volt and oil pressure gauge thats in the consolw into my factory harness and make it look factory installed? Volt gauge=1) yellow/red wire 1) black wire (im assuming ground) Oil pressurr gauge= 1) yellow/red stripe wire 1) yellow/blue stripe wire 1) black wire (im asssuming ground) Quote Link to comment
datzenmike Posted March 23, 2013 Report Share Posted March 23, 2013 You have to go back to the bone yard and get the oil pressure sender and the plug and some wire.. The Yellow/Green stripe is the red warning light in your 620 dash that warns of low pressure. KEEP this in operation!!!!!!! The Yellow/Blue stripe goes to the oil pressure gauge. The Red/Blue and the Red/Yellow wires on the gauges are for the lights. I found it easier to just connect them to something switched on with the ignition and run them full time. Quote Link to comment
riot936 Posted March 23, 2013 Author Report Share Posted March 23, 2013 Word, Is it in the side of the block? Quote Link to comment
riot936 Posted March 23, 2013 Author Report Share Posted March 23, 2013 Once I get it then what? It "T" where the 620 sending unit it is? Quote Link to comment
MikeRL411 Posted March 23, 2013 Report Share Posted March 23, 2013 Once I get it then what? It "T" where the 620 sending unit it is? Good Lord! Even a Texas Aggie can compose a sentence better than that. Quote Link to comment
riot936 Posted March 23, 2013 Author Report Share Posted March 23, 2013 Sorry man auto correct and the layout of this site clashes with my phone screen. I cant see half of what I type. Haha But plz never compare me to or state that a texas aggie is better than me in any category. "Them's fightin words boss" Quote Link to comment
riot936 Posted March 24, 2013 Author Report Share Posted March 24, 2013 What is the pipe plug in the side of the block above the starter? Is that a oil or water passage? Quote Link to comment
datzenmike Posted March 24, 2013 Report Share Posted March 24, 2013 The oil sending unit is in the right side of the block above and to the left of the oil filter. It will have one Yellow/Green stripe wire to it. The sender for the oil pressure gauge is like the picture above and has a Yellow/Green wire for the red dash light warning of low pressure and also a Yellow/Blue wire for the gauge. Just remove the one wire sender and screw in the two wire sender. Splice the Yellow/Green wires together and extend the Yellow/Blue wire so it enters the cab and can be connected to the gauge. What is the pipe plug in the side of the block above the starter? Is that a oil or water passage? If an elbow in the side of the L series head above the starter it's for the heater. If on the side of the block on a Z series motor it for the heater. Both are about the size of your finger. The oil sender is only 1/4" or so in size you can't mix them up.. Here's the two wire oil sender just to the left of the oil filter with the dip stick to it's left. I trimmed the gauge cluster from a 720 and installed it in a blank place on my 710 sedan console. The Canadian ones are Kilo grams per square centimeter but I got one from Canby. Looks better. Quote Link to comment
riot936 Posted March 24, 2013 Author Report Share Posted March 24, 2013 That looks good. Im gonna go back and get it. The plug im talking about is right here. Maybe I can pipe in a aftermarket gauge in case this gauge or sensor is bad. Quote Link to comment
datzenmike Posted March 24, 2013 Report Share Posted March 24, 2013 Block drain for flushing the cooling system. Quote Link to comment
riot936 Posted March 25, 2013 Author Report Share Posted March 25, 2013 Word, thats what I thought. Quote Link to comment
riot936 Posted March 25, 2013 Author Report Share Posted March 25, 2013 Id take that canadian one off your hands. Its pretty badass. Quote Link to comment
datzenmike Posted March 25, 2013 Report Share Posted March 25, 2013 Reads exactly the same just the numbers are different. Quote Link to comment
riot936 Posted March 25, 2013 Author Report Share Posted March 25, 2013 Thats what I like about it. Quote Link to comment
