Lowering a 4 door 510
Dope510
  • Replies 4
Fronts. Remove the stock spring and cut one coil off of it. Carefully trim the bottom spring mount and grind away the weld. Assemble using a split collar and set your ride height. About $25. For another $20 you can replace the strut oil with thicker motorcycle fork oil. Lower, firmer ride for under $50
Rears. Go to wrecking yard or buy new Dodge D-50 front coils and cut them down to 9.5" About $70 or less.
Currently running Ermish coilovers front and rear but before that I had taken my stock springs and cut .5-1 coil at a time until I got the ride height perfect. I really can't complain about the feel of it either. I had to do it 4 times to get it just right . By the end of it I could get the car on jack stands pull all the suspension out and get it back on the groung in 2.5 hours. I think I still have the springs I had cut in my garage if you are near San Jose you are welcome to have them. Not sure iof there is any differences in 2 and 4 dooor springs so may want to check that.
