Slamming 620
I doubt it needs a complete rebuild just thinking about it if it's somewhat cost affective! My problem is its spraying oil to the point that I can't drive it. Put two quarts in drove one mile to my house and lost pretty much all the oil I put in it. Looks like its come out where the head meets the block
  • Replies 43
yeah, because your truck is 74 and before its transmission is the same length as a 510 or 521,, which makes a 5 speed swap a little harder with out modifying the driveline... post 74 620's have a longer tranny, same length as a 280z etc. . . So yes dogleg will work for you...Dont take my word on it but I think if you get a late model 620 drive shaft and a long 5speed it will bolt in...... as for Ka your truck would need engine mounts, you can buy those from redeye here on ratsun, 5 speed from a napz, and if you have already had a long tranny driveline made it will bolt right in.... and you can even carb a ka, wide14u on here did it...
