r0p0doe Posted February 24, 2013 Report Share Posted February 24, 2013 So I have a 71 datsun 510 2dr I'm cleaning up and I need some help identifying a part. I bought a new water pump from AutoZone without a fan clutch because my car has an electric one. But this New pump has no pulley and the pulley from the old pump can't be removed. So if anyone can direct me to where I can get a new pulley for the water pump I'd greatly appreciate it. I've been looking but have no luck, also the new pump has 4 holes in it for the pulley to bolt on to. Thanks ratsuners Quote Link to comment
r0p0doe Posted February 24, 2013 Author Report Share Posted February 24, 2013 Forgot to mention It's an L20b.... Quote Link to comment
MikeRL411 Posted February 24, 2013 Report Share Posted February 24, 2013 There's an outside chance that a Pinto pulley would fit, depending on the backset to your engine block. With luck you might not have to shim to align the fan belt. If it won't align, aftermarket double row chevy small block pulleys are the next attempt but the holes spacing might have to be slotted to fit your spanner hole circle diameter, they are almost always chromed so might be a bit gaudy. Good luck. Quote Link to comment
racerx Posted February 24, 2013 Report Share Posted February 24, 2013 crackerjack69 was selling a pulley.. Quote Link to comment
racerx Posted February 24, 2013 Report Share Posted February 24, 2013 try this one. http://sfbay.craigslist.org/eby/pts/3590502471.html 1 Quote Link to comment
r0p0doe Posted February 24, 2013 Author Report Share Posted February 24, 2013 try this one. http://sfbay.craigslist.org/eby/pts/3590502471.html Any idea what model pulley those are if I can't get one fromn him Quote Link to comment
racerx Posted February 24, 2013 Report Share Posted February 24, 2013 not sure but says 510...call him, good luck. Quote Link to comment
r0p0doe Posted February 24, 2013 Author Report Share Posted February 24, 2013 not sure but says 510...call him, good luck. Sent a txt got no reply, those pulleys look exactly like what would fit. Sucks he's in the bay I was hoping to find someone in driving distance. Trying to have her up and running by Tuesday. Quote Link to comment
racerx Posted February 25, 2013 Report Share Posted February 25, 2013 have you tried your local JY or Craigslist? Fairly sure you have JYs in your area. Also try different datsun forums. Quote Link to comment
r0p0doe Posted February 25, 2013 Author Report Share Posted February 25, 2013 have you tried your local JY or Craigslist? Fairly sure you have JYs in your area. Also try different datsun forums. I got a hold of him, I looked on CL but didn't check any JY's where I could probably find what I need but I'll just buy one fron this guy. Quote Link to comment
