KiroTech Posted February 24, 2013 Report Share Posted February 24, 2013 Anyone know which sway bar would fit a B310 with a SR20 swap in it? Any measurements from one that might fit? Quote Link to comment
datsunfreak Posted February 24, 2013 Report Share Posted February 24, 2013 Betting a sway bar from an '80-83 200SX might fit. :thumbup: Assuming you aren't running a GReddy pan. Quote Link to comment
Davec Posted February 24, 2013 Report Share Posted February 24, 2013 no sway bar on mine, do to running a greddy oil pan Quote Link to comment
KiroTech Posted February 24, 2013 Author Report Share Posted February 24, 2013 Thats the issue im gonna use a greddy oil pan :( Quote Link to comment
datsunfreak Posted February 24, 2013 Report Share Posted February 24, 2013 Thats the issue im gonna use a greddy oil pan :( Probably need to be looking at the custom 510 sway bars built to work with those pans then? FYI, Maddat in Australia makes one specifically for the SR-into-B310 swap. http://maddat.com.au/suspension-parts.php Quote Link to comment
KiroTech Posted February 25, 2013 Author Report Share Posted February 25, 2013 Probably need to be looking at the custom 510 sway bars built to work with those pans then? FYI, Maddat in Australia makes one specifically for the SR-into-B310 swap. http://maddat.com.au/suspension-parts.php yes I did contact them quite a while back but the one they make wont clear the greddy type oil pan Quote Link to comment
datsunfreak Posted February 25, 2013 Report Share Posted February 25, 2013 Get some 300 pound springs for the front and toss the sway bar. B) Quote Link to comment
KiroTech Posted February 25, 2013 Author Report Share Posted February 25, 2013 I think that would be the last option anyways I wont be cornering hard on it anyways, i will be a drag car anyways so I guess I dont have to worry about it Quote Link to comment
datsunfreak Posted February 25, 2013 Report Share Posted February 25, 2013 I think that would be the last option For a drag car, it should be the first option. B) Quote Link to comment
toyota1515 Posted November 20, 2013 Report Share Posted November 20, 2013 A drag car works better without front sway bar buddy, been there done that! You need as much weight transfer as you can and the faster and easyer the better plus 15 to 30 lbs. off of the front end of a drag car is always good! Quote Link to comment
jesusno2 Posted November 20, 2013 Report Share Posted November 20, 2013 torsion style sway bar is the next option, but their far from bolt on into the 210 chassis Quote Link to comment
