Charlie2X Posted February 23, 2013 Report Share Posted February 23, 2013 I bought an 85 720 about 3 months ago for a grand. Runs great. However, there was a small chirp coming from drivers side wheel when I applied the brakes. I bought and installed new rotors, hoses and reman calipers. The chirp is still there. Oddly it seems worse when the weather cools. Any ideas or thoughts would be appreciated. Found this site about a week ago and I've visited it religiously since. Thanks. Quote Link to comment
datzenmike Posted February 24, 2013 Report Share Posted February 24, 2013 Well it's now unlikely to be the calipers and rotors, so try swapping the front wheels and see if it moves. Could be the tension rod bushings on that side. When brakes are applied, the wheel tries to move to the rear of the truck but is held in position by the tension rod. Compressing the worn rubber bushing might cause a squeak. If they have been replaced with polly then this is almost certainly the problem Quote Link to comment
Charlie2X Posted February 25, 2013 Author Report Share Posted February 25, 2013 Thanks. I should have added that it doesn't make the sound when the truck is in reverse and I apply the brakes. I believe this to be in concordance with your diagnosis. Would you agree? Quote Link to comment
datzenmike Posted February 25, 2013 Report Share Posted February 25, 2013 It agrees but could be other things. Inspect the tension bar rear where it bolts to the LCA. Are the bolts loose? What about the front. Is there wear on the rod, maybe a shiny area of rub? Try spraying the front of the tension rod where the bushings are with WD-40 and see if it gets quiet. Is the LCA bushing on the frame mount worn/loose? Is the sway bar secure? Quote Link to comment
MikeRL411 Posted February 25, 2013 Report Share Posted February 25, 2013 I am assuming you installed new brake pads, so you can ignore disc pad wear indicator screeching on the rotor? Quote Link to comment
Charlie2X Posted February 25, 2013 Author Report Share Posted February 25, 2013 Yes MikeRL, I ordered calipers loaded. Going to try WD as DMike suggested. Short on time today, I've been called in to work early. 2nd shifter. Good day to all and thanks for the response. Quote Link to comment
