78 Datsun 510 Flex Plate.
i am in need of one of these. mine for some reason broke around the bolt holes. if anyone has one or has something that will work please let me know, i have looked everywhere for one but cant seem to find anything. this is a picture of what i need. thanks!
not sure exactly what trans i have but the motors a l20b if that helps.
  • Replies 9
huntsvill doesn't tell us much. There's a Huntsville in Ontario Canada. A state or nearby recognisable city sure helps. It's a matter of shipping. If you were in Florida, then people in the same state or close might be more willing to offer. Hell there may be someone very local to you.
There should be a 6 hole spacer in front of it on the end of the crank and another spacer behind it to sanwich it. Did your's have this? If these spacers are missing, it may crack again.
Any 6 bolt L20B automatic flex plate will work for this. 610/710/S10 (200sx) A10 (HL510) 620 and 80 2wd 720s.
I'll check, but the 280z and zx and 810s should work also.
Around '81-'82 a locking torqueconverter was used on most Nissans and the flex plate is much different. Try to get one from the '70s.
  • 4 weeks later...
