hattrickrider Posted February 14, 2013 Report Share Posted February 14, 2013 hi im having a little dilema i cant decide as to which carburetor to use on my z22 im torn between a 32/36 or a dual weber side draft. can somebody hel Quote Link to comment
Dat Lurka Posted February 14, 2013 Report Share Posted February 14, 2013 150$ vs 1050$ Quote Link to comment
datzenmike Posted February 14, 2013 Report Share Posted February 14, 2013 Closer to $300 for the 32/36. http://community.ratsun.net/topic/46085-40mm-mikuni-carbs-wl-series-manifold-55000obo/?do=findComment&comment=736240 Quote Link to comment
Dat Lurka Posted February 14, 2013 Report Share Posted February 14, 2013 Closer to $300 for the 32/36. http://community.ratsun.net/topic/46085-40mm-mikuni-carbs-wl-series-manifold-55000obo/?do=findComment&comment=736240 300$ new... That's a good deal for some sidedrafts. f Quote Link to comment
racerx Posted February 14, 2013 Report Share Posted February 14, 2013 how much you got and practicality = 32/36. with sidedrafts you will have to constantly adjust. With 32/36, you set it a forget it. Quote Link to comment
datzenmike Posted February 14, 2013 Report Share Posted February 14, 2013 Well it's a trade off. 32/36 has less parts to go wrong than multi-sidedrafts. Once set and dialed in either should run ok. A good rule is "Never over carb a motor" Basicaslly you will be happier with a carb that is too small than one that is too large. A side draft carb benifits from the air traveling in a more direct and straight line to the intake valve and are less restrictive at mid to high RPMs. A downdraft has to make a 90 degree bend plus share runners and works best at up through midrange. Multi-side drafts should (or might as well) have a bigger cam to make use if this advantage. Quote Link to comment
