Weber 32/36 pump nozzle has 1 hole or 2 ?
dat521gatherer
  • Replies 7
The large jet holder is on the primary side and came in carburetors that may have been equipped with an electric fuel shut off solenoid. Some carbs had the thread, but not the solenoid. Good luck finding jets for that one. I sometimes will solder the hole shut and then drill it with a jet drill (to make it smaller) or just drill it to make it larger.
Having the two holes in the pump nozzle does not do any good in a progressive linkage carb. You'll be squirting gas into a closed throttle bore. More HP can be gained with other mods to the carb, like larger auxilliary venturis. Unless you swap linkage, keep the single hole pump nozzle.
Sometimes people re-jet them and this is why it's good to check jets before installing them..when you buy something use,y ou don't know the history, specially carbs, unless the person you bought it from can tell you why the JETs are same same or different.
