addison912 Posted January 18, 2013 Report Share Posted January 18, 2013 Just as a preface, I am a complete noob, but I'll try to sound like I know what I'm talking about. I've been experiencing some problems with the e-choke on the hitachi carb of my 1973 620 (it doesn't open). Also the engine has been dieseling long after i turn off the ignition (I actually have to stall it now to get the engine to stop). It appears that the e-choke shares the same relay with the anti-dieseling solenoid. I checked, and there's power going to the relay, but no power to the e-choke or anti-dieseling solenoid. So I popped open the relay and was not surprised to see that the interior was badly rusted and corroded. I tried to clean it up, but to no avail (I probably just did more damage to the tiny fragile wires). Does anyone know where I can find a replacement for this relay? I've checked just about every Pick-n-Pull in Northern California with no luck. If you have any suggestions or advice please let me know, my truck is just about useless without this one little part. Quote Link to comment
banzai510(hainz) Posted January 18, 2013 Report Share Posted January 18, 2013 ck rockauto.com by chance Quote Link to comment
Eagle_Adam Posted January 18, 2013 Report Share Posted January 18, 2013 try rockauto.com EDIT: lolz hainz beat me Quote Link to comment
ggzilla Posted January 18, 2013 Report Share Posted January 18, 2013 RockAuto doesn't sell the relays for the 1973 620. It is different than later 620s. The choke and anti-diesel valve use SEPARATE relays. Nissan Part # 25235-P0101, auto choke 1973 620. Or just throw the relay away and connect the choke to the + wire (WL) in the relay connector. Quote Link to comment
