mntnman Posted January 16, 2013 Report Share Posted January 16, 2013 anyone know where to get front strut inserts for a 71 510, im looking for stock inserts, anyone know a brand that will work. Quote Link to comment
ggzilla Posted January 16, 2013 Report Share Posted January 16, 2013 Stock inserts only come from Nissan. Nissan part # 56110-22526 or 56110-N0725 Quote Link to comment
mntnman Posted January 16, 2013 Author Report Share Posted January 16, 2013 ok any other brands out there work or would i have to make a spacer for my strut tube Quote Link to comment
ggzilla Posted January 16, 2013 Report Share Posted January 16, 2013 No need to make a spacer. Just stack washers in the tube to the correct height. Quote Link to comment
mntnman Posted January 16, 2013 Author Report Share Posted January 16, 2013 so mr2 or some other strut inserts would work if i can can get the body length close Quote Link to comment
Sealik Posted January 16, 2013 Report Share Posted January 16, 2013 http://community.ratsun.net/topic/39512-strut-insert-and-rear-shock-guide/ Quote Link to comment
mntnman Posted January 16, 2013 Author Report Share Posted January 16, 2013 thanks im new to datsuns but i like them and plan on having mine for a long time, ill pull them out and measure things to find the ones i need Quote Link to comment
datzenmike Posted January 17, 2013 Report Share Posted January 17, 2013 Since you have to take them apart anyway to empty out the oil and to remove the strut and valves. Why not just replace the 40+ year old thin hydraulic oil with 20W motorcycle fork oil? I did this for $17 on my 710 but could have spent probably half that. The fork oil is thicker and comes in a variety of different viscosities. The stock oil is like water so something thicker is harder to push through the valving and firms up the ride. Fork oil is full of anti foam agents and rust inhibitors. Quote Link to comment
