Help! timing chain inspection cover stud sheared
Thorpeado
Hey guys, I just got my L20b back from the machine shop and was installing the timing chain inspection cover, and the stud in the head stripped after very little pressure. Does anybody know if this stud is pressed in or is it a threaded stud. Any ideas on the best way to remove it and replace it. thanks any help is appreciated
  • Replies 5
Thanks for the help guys I figured it was threaded in but after one attempted try with vice grips and it shearing off with only a little bit of stud left to grip I figured I'd consult the ratsun community. On the second try I tapped the end with a hammer lightly and was able to back it out after that and replace it. Just got the motor fired up for the first time tonight and it runs like a champ. Pictures of the truck soon to come.
