PineClone Posted January 14, 2013 Report Share Posted January 14, 2013 I think this is probably a simple issue, but wanted to toss it out here to the experts just in case... This past fall I noticed that when i put my B210 in gear the tranny would sometimes not engage. If i increased the RPMs by giving it a little more gas (revving) it would then pop into gear. I have mothballed the car for winter, but on occasion i do start it up. With the colder weather i've noticed the issue has gotten worse. My non-expert diagnosis is that its just an old car and is cold blooded. Once its warmed up and gets moving, seems to be fine. The solution for now is NOT to drop in a 5-speed...though that is on the long-term agenda. Thoughts? Thanks! Quote Link to comment
Eagle_Adam Posted January 14, 2013 Report Share Posted January 14, 2013 checked the fluid level properly? Quote Link to comment
PineClone Posted January 14, 2013 Author Report Share Posted January 14, 2013 I have not checked the fluid. Quote Link to comment
Eagle_Adam Posted January 14, 2013 Report Share Posted January 14, 2013 my girls 710 wagon does that when its low. Do you have a FSM? Quote Link to comment
PineClone Posted January 14, 2013 Author Report Share Posted January 14, 2013 I will check the service manual. Reading a few threads here, i see that it should be checked when warm, and can be easily overfilled. I'm not sure where or how to add fluid, but the manual will hopefully cover that. I replaced the tranny in my 240z about 10 years ago and it required a special hose to fill through a plug underneath. If thats the case, i guess i have the gear. Thanks. Quote Link to comment
Eagle_Adam Posted January 14, 2013 Report Share Posted January 14, 2013 i just use a funnel with a small enough end to fit in the dipstick tube to fill it, and you MUST have it warm and driven so all the fluids circulate for a proper reading. No red drips under the car? Quote Link to comment
datsunaholic Posted January 14, 2013 Report Share Posted January 14, 2013 You fill it through the transmission dipstick. Use Dexron-compatible fluid. And yes, that sounds like low fluid. Quote Link to comment
josh_t Posted January 14, 2013 Report Share Posted January 14, 2013 i agree with the low fluid. almost every car that does that is low on fluid. i blew my input shaft seal in a parking lot and as soon as it hit the L mark on the dipstick it would do that. Quote Link to comment
