Eagle_Adam Posted January 10, 2013 Report Share Posted January 10, 2013 Im looking to put an electric fan into my dads 620, the end result will be on the cheap side and turn on and off with a switch. Suggestions on a fan? Quote Link to comment
Eagle_Adam Posted January 10, 2013 Author Report Share Posted January 10, 2013 the truck is running an L20b Quote Link to comment
heretic Posted January 10, 2013 Report Share Posted January 10, 2013 If you're talking wrecking yard parts, you cant beat a 90-95 Ford Taurus 2-speed fan. Quote Link to comment
Eagle_Adam Posted January 10, 2013 Author Report Share Posted January 10, 2013 wrecking yard, rockauto - dont care. Just need to get my dad rolling again till i can do the proper research and he has the funds. This is a last min change to his build Quote Link to comment
wayno Posted January 10, 2013 Report Share Posted January 10, 2013 Use a stock fan unless there is no other way, but that would be my opinion. Quote Link to comment
Eagle_Adam Posted January 10, 2013 Author Report Share Posted January 10, 2013 for now, a stock fan isnt an option. I need to wrap up his build Quote Link to comment
Skib Posted January 10, 2013 Report Share Posted January 10, 2013 you can just pick one up from the parts store for 50-70 Quote Link to comment
heretic Posted January 10, 2013 Report Share Posted January 10, 2013 If you go the electric route make sure you run relays & heavy gauge wire. They have a HUGE amperage draw at start up. & I personally wouldn't run any electric fan without a thermostatic control switch (adjustable) Quote Link to comment
Eagle_Adam Posted January 10, 2013 Author Report Share Posted January 10, 2013 this is a temp fix, thats only intended to last till the nicer weather begins and my dads wallet recovers Quote Link to comment
Eagle_Adam Posted January 10, 2013 Author Report Share Posted January 10, 2013 was turned onto a cheap option rather than a switch http://www.amazon.com/Hayden-Automotive-3647-Adjustable-Thermostatic/dp/B000C3BB6M/ref=sr_1_9?ie=UTF8&qid=1357859116&sr=8-9&keywords=thermostatic+fan+switch now to find a fan i like Quote Link to comment
Eagle_Adam Posted January 10, 2013 Author Report Share Posted January 10, 2013 fuck it, found a cheap WP with clutch. Yay for friends, this can be locked Quote Link to comment
dr.feltersnatch Posted January 11, 2013 Report Share Posted January 11, 2013 fuck wish i saw this earlier i have an electric fan i woulda sent ya cheap Quote Link to comment
