5 speed gear
i have a 5 speed in one of my trucks and it has a chipped tooth in the 5th gear
all ready opened the case the 5th gear has one band and it's a .87 from what anahiem gear
told me but unable to find the gear can any one help. thanks bert..
  • Replies 4
Pull it from another 5 speed. There must be another laying around somewhere that's been scrapped.
The 5th gears are all pretty much the same and 26 tooth? on the mainshaft and 44 tooth on the countershaft? Can't see how a tooth would get chipped as they are in constant mesh unless there's something loose floating around in the box. The output ratio is a combination of the 26/44 tooth (0.591) and the input/counter drive ratios
thanks for the info the guy at the trans shop gave me the wrong info  didn't think of Nissan
. after cleaning the only thing i can think of is that it was opened and maybe dropped. i got that tranny in 2008
 never had any problems with it not even a leak . so i have no idea. just was driving  heard a pop then she was done..
i'll check with Nissan of Bakersfield in the morning. thanks again. bert
