novita1021 Posted June 18, 2008 Report Share Posted June 18, 2008 any recomndations for a high performace clutch?...its going on my l16 with my dogleg 5-speed...but once i have my L18 rebuilt i wanna drop that in and replace the l16... can i still ise the same clutch? Quote Link to comment
banzai510(hainz) Posted June 18, 2008 Report Share Posted June 18, 2008 L16/18 u can buy a Roadster Pressure Plate 30210-20111 and buy use the stock 510 disc and T/O bearing(Buy new from anywhere.) importedcarparts.com Napa Mr-auto-parts.com Rockauto.com this is a 650KG pressure plat while stock is 350KG Best to buy a new slave for sure and maybe a new master as its a big difference. Could blow out the old rubber seals get from nissanparts.cc or your dealer or maybe Daiken/Exedy Quote Link to comment
novita1021 Posted June 18, 2008 Author Report Share Posted June 18, 2008 the slave and master cyl i alreaady changed about a week ago they where both leaking and i didnt have any presure on it the pedal went all the way down....i also replaced the slave line....but i definately need a new cluth...so its a roadster presure plate huh... and why a stock cluth? i want it to grip and not slip as much.. Quote Link to comment
datzenmike Posted June 18, 2008 Report Share Posted June 18, 2008 Almost any disc will do if in good shape. The pressure plate (that's why it's got that name) does ALL the work of clamping. It just squeezes harder than the stock one. Quote Link to comment
banzai510(hainz) Posted June 18, 2008 Report Share Posted June 18, 2008 why a stock cluth? You must mean clutch disc. Thats all you need. the Pressure plate is the up grade. all the rest will be the same as a stock 510/521 with a 200mm setup. Quote Link to comment
