irishevox Posted November 28, 2012 Report Share Posted November 28, 2012 quick question not sure what the issue is... anytime i stop my truck stalls out. not all the time but most of the time any help would be great. 1980 Datsun P/U Quote Link to comment
banzai510(hainz) Posted November 28, 2012 Report Share Posted November 28, 2012 idle circut.plugged if you have a idle cutoff selinoid installed make sure the wire is hooked up to it. or your mixture needs adjustment Quote Link to comment
LenRobertson Posted November 29, 2012 Report Share Posted November 29, 2012 That was one of my many problems. I may have fixed it today. See this thread: http://community.rat...340-carburetor/ Len Quote Link to comment
datzenmike Posted November 29, 2012 Report Share Posted November 29, 2012 Check that your valves have proper clearance. A tight valve will drop manifold vacuum. Check the ignition timing and condition of the cap/rotor/wires. Damp weather ahead so check those wires. Set the proper idle speed and idle mixture. Getting colder so maybe a simple idle adjustment needed. Grab carb and pull on it does it move on the intake? Vacuum leak from loose bolts. Check any vacuum hoses to the air filter and don't forget the big one to the brake power booster. Pinch them close to the vacuum source and if idle improves then it may be cracked or loose. Don't worry about the vacuum advance or the EGR as there is no vacuum applied at idle. Listen near the back of the carb.... idle cut solenoid should click as you turn the ignition on/off/on/off. Quote Link to comment
irishevox Posted November 29, 2012 Author Report Share Posted November 29, 2012 Thanks for the help you guys i will def check it out in the next few days and keep you updated... Quote Link to comment
