720 5 lug conversion
ssnapz
i looked around and cant find any info. i want to put the 300 zx rear end in my 85 720, but i want to know if anyone knows of a way to convert the front to 5 lug. is there a hub that will go on the stock spindle or maybe a spindle that can go on my truck. any advice or ideas. worst case i can run adapters but i dont want to go that way
  • Replies 9
what i have seen done is that you have to get the 720 spindle machined down to accept the toyota hub.
also i think you can use the toyota spindle and hub but have to modify the lower control arm but not 100% sure
Look into swapping a Toyota 2wd truck front hub. I can't remember the details either the bearing is the same or you need the 'Yoda bearing or something.
First search to come up.... http://www.infamousn...ead.php?t=12628
http://forums.minitruckinweb.com/70/6655565/nissan/how-do-i-do-a-five-lug-conversion/
