68Datsun510 Posted November 5, 2012 Report Share Posted November 5, 2012 So i am in need of stacks for my Mikuni 44PHH carbs, i found these.... http://www.webercarbsdirect.com/product_p/43-6050-2.htm Will these fit mikuni/dcoe style bolt patterns??? Quote Link to comment
banzai510(hainz) Posted November 5, 2012 Report Share Posted November 5, 2012 those are IDF type not the DCOE type. Means Im not sure Quote Link to comment
Silky_Johnson Posted November 5, 2012 Report Share Posted November 5, 2012 I was going to mess around with aftermarket horns on my Mikunis (phh40), but then I found some stock Mikuni horns, so no custom work needed. I have considered buying cheap horns, but there are two issues to keep in mind: 1. the inner diameter of the bottom (carb side) of the horn, which should match the carb inner diameter (44mm); and 2. the bolt pattern. http://www.pierceman...p/52845.225.htm Based on this, it looks like IDFs and DCOEs have the same bolt pattern, but it would appear that the inner diameter might be 1mm too big? Pierce Manifolds recommends "opening up" the IDF 40s so that they mate with the 45mm horns. I'd hate to see someone file their Mikunis for 1mm... I say try it out since they're so cheap, and then let us know how they fit. Should work? Quote Link to comment
Silky_Johnson Posted November 5, 2012 Report Share Posted November 5, 2012 Someone correct me if I'm wrong, but I also believe that DCOEs and Mikunis have the same bolt pattern for the horns. 90% sure. Quote Link to comment
RedBanner Posted November 5, 2012 Report Share Posted November 5, 2012 The question is, do idf's share that bolt pattern. Becouse there down drafts. Well drla's use regular side draft dellorto horns, but that doesn't really mean idf's use dcoe ones Quote Link to comment
Silky_Johnson Posted November 6, 2012 Report Share Posted November 6, 2012 The Pierce Manifolds link shows one type of air horn compatible for both DCOEs and IDFs. I've gotta figure it's the same bolt pattern. http://www.piercemanifolds.com/category_s/172.htm 2 1/4" CHROME AIR HORN. FLANGE MOUNT 45 DCOE, 44 IDF, 40 IDF (FOR BEST RESULTS ON 40 IDF OPEN CARB INLET) CAN USE 99217.250 STACK FILTERS I've also gotta figure that Weber Carbs Direct is selling the same stacks as those on Pierce Manifolds, just cheaper. Weber Carbs Direct doesn't have any real info on their website, but they look the same. I think they're also the same stacks that EMPI sells for IDFs and the VW crew. Quote Link to comment
69srl311 Posted November 6, 2012 Report Share Posted November 6, 2012 Look here also: http://www.borlainduction.com/AirHorn/AirHornsForThrottleBodies.html Quote Link to comment
