jesusno2 Posted October 27, 2012 Report Share Posted October 27, 2012 got a bad connection somewhere or something failed, everything turns on all i get is a relay by the fuse box clicking! cleaned my connections still nothing. any you guys know what those realys do? ones for the electric pump. this is a early model 260 so im unsure if its partial 240 harness. Interlock relay? Quote Link to comment
ggzilla Posted October 27, 2012 Report Share Posted October 27, 2012 Not the interlock relay. You got a KA in there? 240SX has three relays in a row: Fuel Pump A, Fuel Pump B, and ECU relay. Quote Link to comment
jesusno2 Posted October 27, 2012 Author Report Share Posted October 27, 2012 stock 260z not a 240sx Quote Link to comment
ggzilla Posted October 27, 2012 Report Share Posted October 27, 2012 Did you scrape the battery terminals to bare metal? Easy things first. a relay by the fuse box clicking The means you're getting a little power to the harness. But if the cable ends aren't clean it could shut off when you turn it to Start. There is a Intermittent Relay (wipers) and the Defrost Relay over on the passenger side. Quote Link to comment
jesusno2 Posted October 27, 2012 Author Report Share Posted October 27, 2012 yea everything works in the car but the starter i can jump it across so i know it works Quote Link to comment
ggzilla Posted October 27, 2012 Report Share Posted October 27, 2012 Ah OK, now trace the wiring for that. Pull the connector off the back of the ignition switch. Is there continuity betweeen BAT and S when you turn the key to Start? Or only if you wiggle the key a bit? Or could be a loose wire (especially the one at the starter). Or a broken wire. Quote Link to comment
jesusno2 Posted October 28, 2012 Author Report Share Posted October 28, 2012 Heres the deal the car has been parked no ones drivin it in about a month. so what ever happened I have no idea. I have power to some relay down on the kick panel that's just clicking so my ignition switch is working its never not worked or showed signs of not working lol. but i have no power hitting the starter. i cleaned connections from that relay box out. but the weird part is the is a little jumper box next to the battery and if someone unplugs it while i'm holding the key in the crank position, then reconnects it, it will crank. figure that out, cause i cannot! Quote Link to comment
ggzilla Posted October 28, 2012 Report Share Posted October 28, 2012 a little jumper box next to the battery Got a photo? Is it a Nissan part? Could be that someone fit a starter signal relay and it has gone bad. That why they are a bad idea, they add complexity. Quote Link to comment
jesusno2 Posted October 28, 2012 Author Report Share Posted October 28, 2012 FIXED!! key fob batteries went dead for the stupid alarm the car has i forgot all about it! Quote Link to comment
ggzilla Posted October 28, 2012 Report Share Posted October 28, 2012 Good to hear. Quote Link to comment
Ranman72 Posted October 28, 2012 Report Share Posted October 28, 2012 FIXED!! key fob batteries went dead for the stupid alarm the car has i forgot all about it! cool you got it figured out this is funny remember check your batteries lol Quote Link to comment
