supercrawler Posted October 25, 2012 Report Share Posted October 25, 2012 Gurus, Just have them rebuld my dizzy,But,, they lost my rotor, What year and make from nissan this dizzy from? Quote Link to comment
banzai510(hainz) Posted October 25, 2012 Report Share Posted October 25, 2012 all the L20 rotors will fit but I always say 79 200sx/620 Quote Link to comment
Eagle_Adam Posted October 25, 2012 Report Share Posted October 25, 2012 banzai nailed it - 79 620 Quote Link to comment
ggzilla Posted October 25, 2012 Report Share Posted October 25, 2012 To identifiy the year and model, we need the part number stamped onto the side of the distributor. Something like 22100-XXXXX. But the cap & rotor are all the same 1974-1982 or thereabout. Same cap as non-match box. ROTOR * Standard Motor Products JR-79X/JR-79/JR-79T * Bosch 04095, F2020-13435 Quote Link to comment
supercrawler Posted October 25, 2012 Author Report Share Posted October 25, 2012 Sweet!! Quote Link to comment
supercrawler Posted October 25, 2012 Author Report Share Posted October 25, 2012 22100-B9802 Quote Link to comment
banzai510(hainz) Posted October 25, 2012 Report Share Posted October 25, 2012 I assume this dizzy was already on your car and running as you have the mount that this dizzy came with. also assume you running no ballast and a EI coil, not the stock 510 coil you can run the stock 510 coil and ballast you just hook B of matchbox to the + side of the ballast resisitor Quote Link to comment
ggzilla Posted October 25, 2012 Report Share Posted October 25, 2012 Hitachi D4K means matchbox type, 4-cylinder. Nissan 22100-B9802 Parts Catalog says this is from 1980 Datsun 720 Manual Transmission with California emissions. Note that B98 is the 1978-1979 620 Pickup Applied Model Code. So the original design matches that (1979 620s had a matchbox too, but a slightly different 22100-B980x version). Quote Link to comment
supercrawler Posted October 25, 2012 Author Report Share Posted October 25, 2012 You guys are greeeeeeat!! Thanks for all. And for info. Quote Link to comment
