gijosh Posted October 19, 2012 Report Share Posted October 19, 2012 OK, so I've replaced all the fuses and the fusebox. When the headlights come on, i should see some sort of lighting on the dash panel right? So my gauges and such would be illuminated at night. Im not getting that. SOME lights DO come on. Like when the Key turns I get the oil light that comes on. BUt Im asking specifically about the dash lights that light up the gauges so I can see them at night. I turned the little knob on the right hand side that SHOULD be for that purpose, and no response. I checked the connection to the plastic connector and it seems to be solid. IS there a way to test the knobby to see if that fader is good? Quote Link to comment
Eagle_Adam Posted October 19, 2012 Report Share Posted October 19, 2012 lolz, that little "dimmer switch" is such a joke - its easy to take out the cluster i can walk you thru it if needed - i ended up taking mine out to solve my light issues Quote Link to comment
71kat510 Posted October 19, 2012 Report Share Posted October 19, 2012 wanna walk me through it Quote Link to comment
Eagle_Adam Posted October 19, 2012 Report Share Posted October 19, 2012 sure, pm me Quote Link to comment
gijosh Posted October 21, 2012 Author Report Share Posted October 21, 2012 I've noticed it's kinda tight back aroudn the dash area, and I can really see to where different wires run, but I swear, This truck is a spaghetti mess. Should i attempt at taking off the dash to do this? It seems like it would be eaiser to sort the mess that way for one thing. I cant check the connections on the gauges otherwise. Quote Link to comment
datzenmike Posted October 21, 2012 Report Share Posted October 21, 2012 With headlights ON are your tail lights on? Front amber and rear red marker lights ON? If not you won't have dash lights. If the marker and rear lights are on, turn the dash dimmer switch up full. It may have been turned down by accident. Quote Link to comment
ggzilla Posted October 21, 2012 Report Share Posted October 21, 2012 The oil light will come on with the dash just laying there not bolted down. But the illumination lights wont -- the gauge cluster needs to be grounded via the metal tab. Bolt it in and it should work. Or bolt a length of wire from the tab to the dash frame bare metal. 1 Quote Link to comment
