really_drunk Posted October 18, 2012 Report Share Posted October 18, 2012 looking for the thread size for the breather tube on my l16 valve cover.. anyone know or have a breather tube they wanna let go of?? appreciate any help! or any part i can get at a local auto part store that will fit? Quote Link to comment
ggzilla Posted October 18, 2012 Report Share Posted October 18, 2012 Block breather tube? There is no threads, it is a push in interference fit. Quote Link to comment
really_drunk Posted October 18, 2012 Author Report Share Posted October 18, 2012 Actually it's the elbow shaped one on the valve cover I'm looking for. The cover I have doesn't have one.. Quote Link to comment
metalmonkey47 Posted October 18, 2012 Report Share Posted October 18, 2012 looking for the thread size for the breather tube on my l16 valve cover.. anyone know or have a breather tube they wanna let go of?? appreciate any help! or any part i can get at a local auto part store that will fit? Block breather tube? There is no threads, it is a push in interference fit. You're probably better off going to Home Depot and getting something from the plumbing section. I saw a thread somewhere where from someone that did the same thing. 1 Quote Link to comment
datzenmike Posted October 18, 2012 Report Share Posted October 18, 2012 It's glued on. Quote Link to comment
really_drunk Posted October 18, 2012 Author Report Share Posted October 18, 2012 ill check the depot! and Mike i can see threads in there.. Quote Link to comment
datzenmike Posted October 18, 2012 Report Share Posted October 18, 2012 The breather tube that goes to the air filter housing? All the ones I've seen have sealer on them? Never noticed them. Quote Link to comment
metalmonkey47 Posted October 18, 2012 Report Share Posted October 18, 2012 Member babalouie used some generic pipe fitting from the hardware store on his L28 in his Hakosuka to run some copper tube to his catch can. May want to look for his build and see what he used exactly. Quote Link to comment
metalmonkey47 Posted October 18, 2012 Report Share Posted October 18, 2012 http://community.ratsun.net/topic/12649-kgc10-skyline-2000gt-build/page__st__180 Quote Link to comment
really_drunk Posted October 18, 2012 Author Report Share Posted October 18, 2012 Thx MM! Quote Link to comment
datzenmike Posted October 18, 2012 Report Share Posted October 18, 2012 Yup threaded. Quote Link to comment
Dime Dave Posted October 18, 2012 Report Share Posted October 18, 2012 Yup threaded. X2, They are very fine threads too. I tap it to 1/2" NPT. No need to drill the hole, just run the tap into the existing threads and it will clean up to 1/2" NTP.and then you can use a standard pipe thread fitting. The baffle inside needs to come out to get enough room for the tap to run down thru. Removing the baffle isn't a bad idea, it would be very dificult to get all the aluminum chips out if it was left in place. This is one I did that uses a 1/2" NPT to -8 AN elbow. 1 Quote Link to comment
really_drunk Posted October 18, 2012 Author Report Share Posted October 18, 2012 Very nice! Ty! Quote Link to comment
