79620kc Posted October 3, 2012 Report Share Posted October 3, 2012 hey friends B) need some help here guys my fuse panel on the 620 is getting so hot that the glue is melting and letting moisture in the fuse under the drive side dash...only the right side...radio interior lights headlights etc im goin thru fuses like no other HELPPPPPPPPPPP :crying: Quote Link to comment
Z-train Posted October 3, 2012 Report Share Posted October 3, 2012 Too much draw.Clean all connections and i mean all on the truck. Quote Link to comment
datzenmike Posted October 3, 2012 Report Share Posted October 3, 2012 Soak the fuse box in vinegar over night. It unplugs easily enough. the vinegar will remove any corrosion on the brass? contacts. Normally there is zero resistance if the contacts are clean but corrosion and resistance is what makes your toaster heat up. Current through resistance gets hot!!! If those brass contacts get too hot they will loose their temper and not grip the fuses tightly. This makes a bad situation even worse. Oh, and replace the fuses for shiny clean new ones. Quote Link to comment
