question: 81zx 5 speed in 510 with L16 or L20?
Dirty Evo
Try to measure the ratios before you pick it up ... if its a comp NISMO C/R box even better.
The stock ZX 81-83 is nearly identical gearing to the widest option NISMO CR box.... But the 5th gear has a larger drop (good for street) so maybe another option would be better if you want a usable 5th on the track.
  • Replies 26
The T-5 had wider ratios because of the low 3.50 first gear to get the turbo spooled quickly.
The '79 620 and '80 720 had a 3.594 first and spread out gears., but was mated to a 4.11 diff instead of the usual 4.375.
I can't imagine why anyone would want to change a close ratio zx into one of these. First and second are so low they are almost unusable for racing.
