SHORTDOG Posted September 20, 2012 Report Share Posted September 20, 2012 If i run 3"-4" blocks in the rear, how many full turns should i give the torsion bars to drop even with the rear?? In other words, how much of a drop will i get with each full turn of the torsion? (after settling of course) Quote Link to comment
datzenmike Posted September 20, 2012 Report Share Posted September 20, 2012 Unknown, as most just turn it down and set it on it's wheels and look at it. Adjust up or down as required. Do both side equally at the same time. Adjusting the ride height WILL affect the toe in and camber. Toe can be fixed by yourself. Quote Link to comment
Pacific coast Datsun Posted September 20, 2012 Report Share Posted September 20, 2012 In general 3-4 turns on the torsion bar bolt gives you 1 inch of drop. Measure height before you start then compare afterwards. Quote Link to comment
