doomdatsun Posted September 17, 2012 Report Share Posted September 17, 2012 hi, been having problem at idle and low speeds, at night the lights were weak and while hitting the gas it gets strong. Today I checked the alternator and found it had no stable voltage, ranged reading from 1.2 V or 0 V up to 16.01 V, tryed removing the neg post and activated the lights and headlights and tried to rev the motor, it would rumble and bog like a bull then stall, so I'm sure its the alternator. question is it repairable, I mean is it the carbon bushings or the rectifier or should I buy a new one ? Quote Link to comment
DanielC Posted September 17, 2012 Report Share Posted September 17, 2012 If you can replace the brushes in the alternator easily, do that. In fact some of the alternators used on 1970's Datsun were set up so you could remove two screws that held the brush assembly, and you could then slip a new unworn brush assembly into the alternator, without having to disassemble the alternator. If the alternator has other problems, probably replacement is a good way to go. Quote Link to comment
banzai510(hainz) Posted September 17, 2012 Report Share Posted September 17, 2012 1.2 V or 0 V up to 16.01 V WHAT???????? it should never go to 0 volts as the battery is in the sytem. Simple pull battery out take to parts store and have it cked with a load. WHO CARES if its the bushings or not. There are about 35 to 40 $ for a new one. Most likely its the bushings. Unless your good at figureing things out then just get a new one. Most times when ytou do a alternator test as you mentioned never put the lights on as it will kill it. Since you got a 510 does it still have the external volt reg? You have a L16 block or a L20 block? this will determine the bolt hole size. Quote Link to comment
doomdatsun Posted September 17, 2012 Author Report Share Posted September 17, 2012 wow wow, guys I never said I had a 510, here this is what I have its a datsun laurel C31 1983 model as for putting the lights on while testing it should be normal cuz the alt should provide enough juice to power everything in the car so, removing the battery should just relief the load on it. After changing my clutch fan, I started hearing metal grinding noise, I suspected the alt and now I'm sure of it. Quote Link to comment
banzai510(hainz) Posted September 17, 2012 Report Share Posted September 17, 2012 Wehn I did this to my 510 the light would die. Since this is a 83 I assume the volt reg is with the alternator. most likely that is it(alternator) simple fix. if you have the resources to a solder iron/flux you can swap out the brushes Quote Link to comment
doomdatsun Posted September 17, 2012 Author Report Share Posted September 17, 2012 if it is a normal solder and flux then I do have them (for electronic parts etc), not sure though about the alt bearings, I fear they might be bad. to tell the truth I don't want to spend much money, its just that I'm nearly broke these days and got lots of things to do with the car Quote Link to comment
banzai510(hainz) Posted September 17, 2012 Report Share Posted September 17, 2012 I replaces bushes once just to learn how to do it. Now I have so many alternator I just swap them in. Most alternators are fairly cheap. Nissan Dealer ones are better but are getting expensive. I bought my dealer ones when they were cheap and bought a few spares. Quote Link to comment
