Grant wheel adapter doesnt fit?
Hey folks, slight issue Ive been frustrated by for years, i have a grant wheel adapter, but it doesnt reach the horn contact, bending a curved contact upward to reach it also brings it more towards the center, and i get accidental BEEPS when i turn the wheel.
Has anyone else had this SILLY issue?
69 510 btw...
  • Replies 8
I'm running the grant adapter with a quick release. When I initially wired it up the horn was going of at random points in the turning radius, turned out that when I'd been putting it together I'd pinched the wire housing and it had gone through to the wire so whenever the bare wire at that pinch point came in contact with metal my horn would sound.
Wrapped the wire with electrical tap at that point, no more intermittent beeping.
on the hub for my nardi the contact and the pegs for the signal return whernt even close enough to function.
I just moved the turn signal assem. and cover forward up the the column till they where at perfect distance.
but Im also not using the stock ignition switch and its completely tossed out
so that and the steering lock spot whernt an issue for me
