skyblue Posted August 29, 2012 Report Share Posted August 29, 2012 Hey guys i'm looking for the flange yoke that came on stock 4spd tranny's for a 521. I need the whole assembly, just the yoke not the drive shaft. It's the one on top in pic. thanks. Link to comment
kike69 Posted August 30, 2012 Report Share Posted August 30, 2012 do you have any pictures for the parts you have 4 sale????? Link to comment
skyblue Posted August 30, 2012 Author Report Share Posted August 30, 2012 I don't have parts for sale, i'm looking for the above part. this is the parts wanted section. parts for sale is a different section. Link to comment
banzai510(hainz) Posted September 2, 2012 Report Share Posted September 2, 2012 the521 will have a 22-27mm nut on the back that goes on the trans end and nut hold it on then the other flat flange mates to it. those photos above dont look like it ,but maybe im wrong Link to comment
datzenmike Posted September 2, 2012 Report Share Posted September 2, 2012 I thought it looked right. Would look like this with the driveshaft unbolted... . Link to comment
skyblue Posted September 2, 2012 Author Report Share Posted September 2, 2012 yup. that's right mike. i'm using a dogleg so i can remove the whole D/S without the nut. Link to comment
datzenmike Posted September 2, 2012 Report Share Posted September 2, 2012 You should have said so.... Just put the lower one on in this picture Just un-do the U joint and join it on there. Tooooo easy. . Link to comment
skyblue Posted September 3, 2012 Author Report Share Posted September 3, 2012 well the problem is the lower one won't slide on cause of the dust shield/guard. the dogleg has a dust shield on it too so they conflict. i need another bolt on type yoke for my one-piece shaft. why don't i just use the one on there you ask? cause i need to get the one-piece balanced before i put it on the truck and i currently don't have a place to take the shaft off. Link to comment
datzenmike Posted September 3, 2012 Report Share Posted September 3, 2012 The 200sx dust cover will pull off. Or maybe trim the shield on the lower spline. It may be tacked on or pressed. Link to comment
skyblue Posted September 3, 2012 Author Report Share Posted September 3, 2012 well the dogleg is from a 78 510 wagon. will the dust cover pull off it also? Link to comment
