rad510 Posted August 28, 2012 Report Share Posted August 28, 2012 im looking for some strut bar for my 510 let me know if s13 strut bar fit ? or what i got to do with the strut bar to make it fit Quote Link to comment
Tristin Posted August 28, 2012 Report Share Posted August 28, 2012 They already make strut bars for the 510. They surface on eBay from time to time and some people make their own. I know a few that make them. Quote Link to comment
Skib Posted August 28, 2012 Report Share Posted August 28, 2012 the 240sx one is too wide. if you can fab you can shorten it. Quote Link to comment
datzenmike Posted August 28, 2012 Report Share Posted August 28, 2012 I wouldn't spend much on one as they don't do much. More for show really. Like a header or wing or drilled rotors or hood pins or amber middle lights or catch can or cone filters or polly bushings or..... Unlike a sway bar, or spray bar or high volume oil pump or EI dizzy or camber plates or oil cooler or tach or new shocks or tires or brakes.... Quote Link to comment
Tristin Posted August 28, 2012 Report Share Posted August 28, 2012 The only strut bars I have faith in are the 3pt. 1 Quote Link to comment
datzenmike Posted August 29, 2012 Report Share Posted August 29, 2012 These are a "monkey see, monkey do" "feel good" accessory. They do nothing significant on a stock car and everyone has one, but the owner feels good about his new accessory. Any improvement in actual rigidity realized from these braces is a result of the owners imagination and expectation and increases with the cost. I defy anyone to tell weather they have a brace on or off under a blind test. Quote Link to comment
lil89ram50 Posted August 30, 2012 Report Share Posted August 30, 2012 I wouldn't spend much on one as they don't do much. More for show really. Like a header or wing or drilled rotors or hood pins or amber middle lights or catch can or cone filters or polly bushings or..... i am going to have to dissagree on the amber lights, cone filters, AND polly bushings. you can tell a difference with every one. 1 Quote Link to comment
datzenmike Posted August 30, 2012 Report Share Posted August 30, 2012 Amber lights 'see' further into fog and rain with less light reflected back at the driver, but most just paint them because everyone else does. Most night driving is done in clear/good weather and coloring the lens merely reduces light output on hi beams. So you see less further. Air filters are air filters as long as they are clean. If you can remove and wash and replace then I'll give you that they are an advantage. Do they make or free up enough hp to notice? Maybe if replacing a really dirty stock one, otherwise the ass dyno always lies. Poly bushings I think have proven themselves to be not as fabulous as everyone used to think they were. You can't beat good new rubber bushings. Yes, they maybe could be very slightly stiffer, but polly ones might as well be made of metal. There is no give or twist as in rubber and they chafe and wear out or they squeak. Polly bushings on the tension rods are so inflexible that the bar has to bend around them causing fractures and failures. Just like replacing the dirty air filter above, replacing 40 year old rubber with polly will always be 'better'. You drive it for a few years and you'll see they wear and/or they make noise. This is race car territory, street cars seldom need this degree of firmness. These are only my opinions on the subject. By definition an opinion is neither right or wrong but a personal interpretation of facts. 2 Quote Link to comment
lil89ram50 Posted September 2, 2012 Report Share Posted September 2, 2012 touche' mike. well explained. my exact thoughts. they are good improvement for SOME people. like me, we got a ton of snow here, and its always blowing. hence the amber lights do help a lot with vision. Quote Link to comment
datzenmike Posted September 2, 2012 Report Share Posted September 2, 2012 ND.... wow. Spent a winter night in my car in a rest stop in ND. Quote Link to comment
