Locsteros22 Posted August 24, 2012 Report Share Posted August 24, 2012 Finally have time to get on here but with another problem!! Well I recently purchased a 78 620 and now after a few months she started shaking when I accel at high speed...I though the clutch is going out so I changed the clutch which looked gone so it was worth the week of work haha but after I put her back together she still shakes like crazy...any idea what can be wrong guys? Quote Link to comment
datzenmike Posted August 24, 2012 Report Share Posted August 24, 2012 Look at your tires for missing balance weights that have come off. Lift and spin them looking for bulges in the tread or sidewall. Check driveshaft for damage (dent or bent) look also for a clean spot where a balance weight has come off. Inspect for U joint wear.... if loose or you can wiggle them they are no good. They should turn only. Check engine and transmission rubber mounts and bolts for looseness. Use a 2x4 to pry with. Quote Link to comment
.blackgt. Posted August 24, 2012 Report Share Posted August 24, 2012 Sounds like a U- joint from my past experience. 1990 F-150, under 45 was nice, go 46 to 55 and it would shake as bad as you have described. Like King Rat said, check all of those components for wear. Quote Link to comment
Locsteros22 Posted August 24, 2012 Author Report Share Posted August 24, 2012 Ok thanks guys I'll check those things when I get home...shoul have checked it since I have the whole drive shaft and tranny disassembled Quote Link to comment
Locsteros22 Posted August 24, 2012 Author Report Share Posted August 24, 2012 If it's my mounts is there anyway of replacing them without taking out the whole motor? Hhaha I know it's a stupid question but I really don't have access to a crane. Quote Link to comment
Lee R Posted August 24, 2012 Report Share Posted August 24, 2012 You just need to loosen the bolts holding your old mounts and slighlty jack up the motor just enough to get them out and replace with new ones. Quote Link to comment
Locsteros22 Posted August 24, 2012 Author Report Share Posted August 24, 2012 Sweet thanks brothers!! Quote Link to comment
metalmonkey47 Posted August 25, 2012 Report Share Posted August 25, 2012 You just need to loosen the bolts holding your old mounts and slighlty jack up the motor just enough to get them out and replace with new ones. Yup! Did my engine mounts on my 620 in about 30 minuets, and that included cleaning the mount brackets. Quote Link to comment
Datsun R Fun Posted August 25, 2012 Report Share Posted August 25, 2012 feel i should say this, my carrier bearing went on drive shaft and when i hit about 40+ is shakes like mad, feels like get unstablized . just another thought Quote Link to comment
