davydavidoff Posted August 19, 2012 Report Share Posted August 19, 2012 i just got a set of t3 weld on coils and im not sure where to weld on the spring pertch. if any one knows let me know asap please Quote Link to comment
datzenmike Posted August 19, 2012 Report Share Posted August 19, 2012 Get 2" split collars. Totally adjustable and each will hold 6,000 pounds. That's about 3 510s each. Welding is fine but what if you want them off later? Oh... collars are about $10 each, reusable, don't need a 220v supply or welding skillz either. Quote Link to comment
Skib Posted August 19, 2012 Report Share Posted August 19, 2012 how long are the sleeves? Quote Link to comment
VintageRice Posted August 19, 2012 Report Share Posted August 19, 2012 Mikes right. I did weld on's. Went too low, thought I had it figured. Ended up buying the slpit collars on ebay and putting them on. Thanks goodness I didnt weld them on to high. That woulda been a pain in the arse. Quote Link to comment
gypsy punk Posted August 20, 2012 Report Share Posted August 20, 2012 the struts are how long are the sleeves? this is for my wagon i kinda hijacked ryans account earlier but the strut housings are 11.5" and they are the ground control weld on form t3 Quote Link to comment
Skib Posted August 20, 2012 Report Share Posted August 20, 2012 yeah but how long are the coilover sleaves? Quote Link to comment
gypsy punk Posted August 20, 2012 Report Share Posted August 20, 2012 umm im not exactly sure they are down at the shop. but they are the techno toy tuning weld on, 200 lb spring rate Quote Link to comment
Skib Posted August 20, 2012 Report Share Posted August 20, 2012 cant really help if idk how long it is, brand doesnt matter when it comes to where you need to weld the perch Quote Link to comment
5NDIME Posted August 20, 2012 Report Share Posted August 20, 2012 If they are the T3, they should be 7"....that is also what she said. 1 Quote Link to comment
datzenmike Posted August 20, 2012 Report Share Posted August 20, 2012 Use the split collars and try them until you get them where you want... then weld. But you won't need to then. Quote Link to comment
Tice Posted August 20, 2012 Report Share Posted August 20, 2012 Get 2" split collars. collars are about $10 each Where can I find these at, Mike? I'm interested Quote Link to comment
datzenmike Posted August 20, 2012 Report Share Posted August 20, 2012 Fastener supply companies will have them or can get them. Made in China. 2" for most Nissan struts. Quote Link to comment
Skib Posted August 20, 2012 Report Share Posted August 20, 2012 Where can I find these at, Mike? I'm interested Ruland makes them Quote Link to comment
Skib Posted August 20, 2012 Report Share Posted August 20, 2012 here the T3 complete kit with ground control sleeves on 510 struts. should be pretty self explanatory from there Quote Link to comment
