Anyone used/seen one of these voltage regulators?
GERMS
I bought a donor 620 and the external alternator on the L18 has what seems to be a plug in voltage regulator that plugs in the F N connector. The truck has no wiring at all, it was all pulled by previous owner so not sure if he did the bypass on the harness. Ill be using this alternator with the donor L18 for now until Im ready for my KA swap, I assume I have to do the bypass thing at the voltage regulator connection if I use this right?
  • Replies 3
