datO))) Posted August 14, 2012 Report Share Posted August 14, 2012 Will a 620 steering box convert to a 520? Mine is leaking Quote Link to comment
wayno Posted August 14, 2012 Report Share Posted August 14, 2012 Will a 620 steering box convert to a 520? Mine is leaking A 521 steering box/column will fit, don't know about the 620 assembly. Quote Link to comment
datzenmike Posted August 15, 2012 Report Share Posted August 15, 2012 Will a 620 steering box convert to a 520? Mine is leaking Get a puller and remove the pitman arm. There is a seal up in there that you should be able to tighten a long screw into. Maybe two of them. Use vice grips to pull it down and off the sector shaft. Grease a new seal so it isn't dry and use a socket to tap it up into place. The lower 521 seal is 48137-36700.... about $4. Use this number to cross reference from NAPA or Lordco.... I've done this with a 620 box and it had a C clip and washer and then the seal. I don't think the 521 has these but it may. Quote Link to comment
datO))) Posted August 16, 2012 Author Report Share Posted August 16, 2012 Nice thanx guys. It's hella hard to find datsun scrap so when I see one I try to see if I can apply any of it to my 520 . Quote Link to comment
