Lopez916 Posted May 26, 2008 Report Share Posted May 26, 2008 Should i remove my lowering blocks or run a taller tire? right now i have 16 x 7 in the front there like 50series in the rear it has some ugly mag type wheel that are 15 x 7 with 70 series huge. If I try to put the 16 x 7 50 series in the rear my shackle that holds the shock rub the inner wheel which prevents it from turning. This is y im assuming they ran a huge tire in the rear with the 15inch rim. so if I remove the lowering block will this elminate my problem and allow me to fit my 16 x 7's all the way around. Quote Link to comment
808DA6 Posted May 26, 2008 Report Share Posted May 26, 2008 You're running into an offset issue. You will need a spacer to run the 16x7's in the rear. Removing the block won't help. -Brian Quote Link to comment
Pacific coast Datsun Posted May 26, 2008 Report Share Posted May 26, 2008 808 is correct. The rims are probably hitting the leaf springs too. Get a 1/4 inch spacer from any tire shop & that should push em out enough. Quote Link to comment
haubstr Posted May 26, 2008 Report Share Posted May 26, 2008 I'm running a 1/2" spacer with the same exact rims with 205/40/16... When I had the 4" lowering blocks on it, it was hitting the inside of the tire... I ended up taking out the 4" blocks, taking the leaf springs apart, flipping the main leaf over and putting them back together... I don't recommend this because of how rough the ride is, but I wanted mine low... I think I'm still going to add 1" blocks back in... Quote Link to comment
Lopez916 Posted June 2, 2008 Author Report Share Posted June 2, 2008 thanks spacer and grinding was needed to fit Quote Link to comment
