sr71sss Posted August 8, 2012 Report Share Posted August 8, 2012 looking for a 5 spd for my datsun 620 std cab truck, I have a good 280zx 5 spd in trade, I know it will require the driveshaft and crossmember too anyone in the san francisco bay area have one willing to trade for a good 280zx non turbo transmission, can pick up up anywhere in the bay area txt me with info or leads 650-302-5127 Link to comment
Ranman72 Posted August 8, 2012 Report Share Posted August 8, 2012 so you are looking for a truck 5 speed and have a zx 5 speed to trade ?? Im a little confused as to what you need Link to comment
sr71sss Posted August 8, 2012 Author Report Share Posted August 8, 2012 so you are looking for a truck 5 speed and have a zx 5 speed to trade ?? Im a little confused as to what you need correct sir I need the truck shortail 5 spd, trying to keep the swap simple, doing a friend a favor, dont want to create a big project for me-too many cars to fix right now Link to comment
datsunaholic Posted August 8, 2012 Report Share Posted August 8, 2012 The 620 5-speeds are all longtail. The 280ZX trans should fit any 74-79 with no mods except changing the speedo pinion. The only truck shorttails were on later NAPS-Z 720s, and even then it wasn't all of them. Link to comment
Ranman72 Posted August 10, 2012 Report Share Posted August 10, 2012 correct sir I need the truck shortail 5 spd, trying to keep the swap simple, doing a friend a favor, dont want to create a big project for me-too many cars to fix right now datsunaholic is correct the stock truck tranny should be the same length as the zx tranny but if your looking for a long tail truck tranny I have one the short trannys were only in the early trucks like the 521 I think all 620,s had the long tail tranny Link to comment
datsunaholic Posted August 10, 2012 Report Share Posted August 10, 2012 The 73 had a short tail trans, but there were no 5-speeds available then. It's possible to use a dogleg 5-speed in a truck, but it's inadviseable. Plus it's not as easy as it sounds since the mount is not in the same place as the original 4-speed nor in the location of the later longtails. Link to comment
datzenmike Posted August 11, 2012 Report Share Posted August 11, 2012 '72- Sept '73 620s with L16 had short (26") F4W63 4 speeds and 3N71B automatics. All L18 and L20B equipped trucks from Oct '73 on had long (31.5") transmissions. Link to comment
Naco1 Posted August 13, 2012 Report Share Posted August 13, 2012 So to confirm. If I buy this. It will drop right in my 75 620 with a simple change of the tranny mount, correct? Link to comment
datsunaholic Posted August 13, 2012 Report Share Posted August 13, 2012 If you buy the 280ZX trans for a '75 620? Drops right in- use the crossmember, soft mount, throwout bearing collar assembly, and slave cylinder from your EXISTING 4-speed. Link to comment
