flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 See now if you guys had a Tri-cities meet and greet like you were threatening to do,,, this would have all been hammered out already... just sayin :) We do. I do. That's how I got into this mess with the truck's previous owner. Quote Link to comment
uberkevin Posted August 9, 2012 Author Report Share Posted August 9, 2012 Oh and by running wired I mean It died a few times costing to a stop and turning.. also just sounds wired Quote Link to comment
flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 Suck, squish, bang, blow. Figure out which is missing-truck fixed. Quote Link to comment
uberkevin Posted August 9, 2012 Author Report Share Posted August 9, 2012 Not following.. :confused: Quote Link to comment
flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 Not following.. :confused: Suck, squish, bang, blow. A motors 4 cycles. Induction, compression, ignition, exhaust. Air and gas go in. Air and gas get compressed in a closed chamber. Air and gas get ignited to create an explosion. Ignited air/fuel mixture is expelled from motor. Gap your points. See where that gets you. Do you have a service manual? Quote Link to comment
uberkevin Posted August 9, 2012 Author Report Share Posted August 9, 2012 Yeah Ive got a few, I fellow you up to "gap you points" Sorry if I'm hella irritating. The help is much appreciated!! Quote Link to comment
flatcat19 Posted August 9, 2012 Report Share Posted August 9, 2012 The points are in the distributor. They are what distributes the spark to the plugs. They need to be at a certain clearance to be able to work. New ones are cheap. Feeler gauge is like $4 at Harbor Freight. Half an hours worth of work will do wonders. Quote Link to comment
uberkevin Posted August 9, 2012 Author Report Share Posted August 9, 2012 cool thanks! Quote Link to comment
uberkevin Posted August 10, 2012 Author Report Share Posted August 10, 2012 So every fuse in my truck was the wrong size.. "not my doing" There was 30s in the spot of two 15s. and 25s in the spot of 10s. Quote Link to comment
uberkevin Posted August 11, 2012 Author Report Share Posted August 11, 2012 So my 521 is running a lot better! I also have one runnning light working "better than not working at all" and it either the bulb or a wire somewhere. Almost my everyday truck now all I need is the reverse lights and a new water pump "Don't wanna deal with any leaks". Thanks again Ratsun! :thumbup: :thumbup: Quote Link to comment
flatcat19 Posted August 11, 2012 Report Share Posted August 11, 2012 Bring this thing by my work tomorrow. I want to meet ya. PM me. Quote Link to comment
Eagle_Adam Posted August 14, 2012 Report Share Posted August 14, 2012 keep up the work!!! Quote Link to comment
banzai510(hainz) Posted August 14, 2012 Report Share Posted August 14, 2012 read olddatsuns.com the tech section!!!!!!!!!!!!! reverse lights are a minor issue if any. worry about the running lights and headlites and blinks. make sure bulbs are ok %21 you can get to the back side of the lamps turn it left and the housing will come out. replace bulb if needed. Quote Link to comment
