kinetisist Posted July 19, 2012 Report Share Posted July 19, 2012 I picked up a tranny out of a 210 and here are some picshttp://photobucket.com/60tranny and i need to check something .. what is the plate on the side for ? and is this a 5 or 4 speed how to ID? Quote Link to comment
DRIVEN Posted July 19, 2012 Report Share Posted July 19, 2012 I can't get your link to work. Can you post the pic directly in the thread? Quote Link to comment
datzenmike Posted July 19, 2012 Report Share Posted July 19, 2012 Looks like an FS5W60L dogleg to me but I'll have to check when I get home. Get a shifter or a screwdriver and shift in the upper left position. Turn the input shaft.... If it reverses then you have a dogleg 5 speed. Quote Link to comment
DRIVEN Posted July 19, 2012 Report Share Posted July 19, 2012 Nevermind. It's working now. Looks like a 60-series 5 speed. More info here: http://datsun1200.com/modules/mediawiki/index.php?title=5-Speeds Halfway down the page. Quote Link to comment
kinetisist Posted July 26, 2012 Author Report Share Posted July 26, 2012 thanks for the help .. turned that input shaft and the shaft turned the same way .. yeah..60a non dogleg tranny ...score .. 100 at pick n pull including core .. caught them on a sale day Quote Link to comment
datzenmike Posted July 27, 2012 Report Share Posted July 27, 2012 Yes it's easy to mistake the downward pointing drain bung for the shift arm bracket used on all doglegs. Another thing I missed was the reverse check sleeve in this picture... (looks like a fuel pump block off plate) Was introduced in '80 and there were no FS5W60L doglegs used after the '79 model year. . Quote Link to comment
BillM Posted August 1, 2012 Report Share Posted August 1, 2012 That diamond shaped plate is the "lock-out" to prevent you from going into reverse from 5th without wiggling the shifter in neutral first. Prevents you from accidentally going into reverse instead of forth when downshifting. (just like King Rat said) BillM Quote Link to comment
