Pleadingbark Posted July 16, 2012 Report Share Posted July 16, 2012 Its hot, Im weak and I want AC. What are you guys doing for A/C In your z cars? Its a 240z that originally had factory AC but I yanked it since it didnt work and was dead weight basically. Now Im seeing the errors of my ways and want to go back to having ac in the car. What are you guys doing for it? Is there some system I can hook up into it? Quote Link to comment
sedition88 Posted July 16, 2012 Report Share Posted July 16, 2012 If your car was set up with AC to start with I'd resource the factory parts again. I'm in the process of building myself a swamp cooler for my 620, mostly for the hell of it. Quote Link to comment
ggzilla Posted July 16, 2012 Report Share Posted July 16, 2012 240Z didn't have factory A/C. Dealers added A/C kit to them. You can get a kit from JC Whitney. Quote Link to comment
jalen Posted July 16, 2012 Report Share Posted July 16, 2012 Of get a VW AC cooler haha No but rocky auto has kits to that are prettycool and easy Quote Link to comment
ggzilla Posted July 16, 2012 Report Share Posted July 16, 2012 The VW kit will work for the inside, but where it bolts to the VW engine is different. Hopefully you still have the 240Z engine brackets. http://www.oldairproducts.com/catalog/ac-systems-parts/custom-street-rod-ac-units-c-1_32000000.html Quote Link to comment
jalen Posted July 17, 2012 Report Share Posted July 17, 2012 I was talking about the ones that go on the window Quote Link to comment
ggzilla Posted July 17, 2012 Report Share Posted July 17, 2012 You mean a swap cooler? Those were popular on old american cars, guess they would work on a VW too. Best bet for a 240Z is find someone who is selling the whole works, and bolt it up with a new dryer, take it to an A/C shop for charging. Easy as 1,2,3. Find, install, charge. Quote Link to comment
Jarvo2 Posted August 7, 2012 Report Share Posted August 7, 2012 I have a dealer-installed A/C kit with many NOS parts that I'm looking to sell. See below... http://www.datsunclassifieds.com/showproduct.php/product/7226/title/72-dealer-installed-a-c-kit/cat/4 Quote Link to comment
San Maru Posted August 7, 2012 Report Share Posted August 7, 2012 My 260z had factory air conditioning but the previous owner was too stupid to be able to fix it and he yanked all the engine bay parts. Since 280z often has A/C I went to a parts yard and got the parts. Start at the 2 row pulley and condensor and work your way back to the HVAC controls. Forget about the Vacuum Canister and the solenoids for Fidle and use your choke lever to idle up. One thing you want to do is swap your blower motor for a 90s kia sportage one at a junkyard. You have to modify the mounting point but it puts out a lot more air. Most blower motors turn the opposite way so not all of them will work like the kia unit. If you have the money go with the aftermarket modern kit, if not, you cant beat bolt on used parts. You want the drier new anytime the lines are open. Good luck. Quote Link to comment
tamo3 Posted August 7, 2012 Report Share Posted August 7, 2012 Hi Jarvo2, I'm interested in your A/C unit. In order to install '72 240z, is there any part is required? Thanks Quote Link to comment
Jarvo2 Posted August 8, 2012 Report Share Posted August 8, 2012 I believe you'll need new hoses and belts and possibly an idler pulley for adding tension to the belt. Drop me a PM with your email address & I can give you more specifics. Quote Link to comment
Tice Posted August 19, 2012 Report Share Posted August 19, 2012 I yanked my AC for the same reason the OP did... Hope I don't have to move somewhere where I wished I hadn't and end up with this same problem! :geek: Quote Link to comment
