ggzilla Posted July 14, 2012 Report Share Posted July 14, 2012 Center of P in TEMP is about 175 degrees per Mike's diagrams. It also says 20 ohms is 180 degrees, again very fine. Especially for having no fan. 175-180 is a very nice temp. No problem there. I would double-check those temps with either a temp gun ($25 at Harbor Freight) or thermostat in a pan of water with a cooking thermometer. Quote Link to comment
banzai510(hainz) Posted July 15, 2012 Report Share Posted July 15, 2012 Its hard to find those adapters. I had found only one that fit a stocl L16. L20s temp housings had 2 to maybe 3 ports to try to get soemthing to work Quote Link to comment
gonzo Posted July 17, 2012 Author Report Share Posted July 17, 2012 Hey Datzenmike, I only noticed one plug on the passenger side on the block towards the back of the engine. It seemed a bit tight, so I didn't want to push too hard till I made sure that I can flush thru it! Yeah Hainz, am having a hard time trying to find an adapter. I think the bolt thread is M16x1.5 but not 100% sure. I found one that says its a 1/8 NPT to M16x1.5 but it's for oil pressure so not sure if it will work! Is there anywhere else I can place the Temp Sender? Maybe where the heater line goes? (no heater connected). Quote Link to comment
