78silvia200sx Posted July 1, 2012 Report Share Posted July 1, 2012 What are the 2 sensors on the tranny Called? And where could i fine them new? Quote Link to comment
bonvo Posted July 1, 2012 Report Share Posted July 1, 2012 well i know one is reverse lights the other i think is smog related Quote Link to comment
78silvia200sx Posted July 1, 2012 Author Report Share Posted July 1, 2012 Yeah i was thinking it was the reverse/neutral switch for the one. Quote Link to comment
datzenmike Posted July 1, 2012 Report Share Posted July 1, 2012 (yes ggzilla this is an a series dogleg, but it's the only picture of a dogleg with all the switches that I have) There are three possible switches. Only the Canadian '77 200sx had the neutral switch located high up on the right rear of the tailstock just forward of the shifter. All 200sx doglegs have the 'Top Gear' switch located low down and to the front of the tailstock. (lower right in the picture above) and all had the reverse light switch located just above the top gear switch in the middle. The HL510, besides having a reverse lamp switch, had a top gear switch through '79 with the L motor and from '80 on with the Z series motor had only the neutral switch. Quote Link to comment
78silvia200sx Posted July 1, 2012 Author Report Share Posted July 1, 2012 Thank you this explains alot. Quote Link to comment
78silvia200sx Posted July 1, 2012 Author Report Share Posted July 1, 2012 Mine only has the reverse light and the top gear switches. And the wires to my reverse light switch are broken off. Quote Link to comment
datzenmike Posted July 2, 2012 Report Share Posted July 2, 2012 That reverse light switch can be found in all the 240z through 280zx non turbo, B-210, HL510, 200sx through '86, '74 and up 620 4 and 5 speeds, 810/Maximas gas or diesel, 720 4 and 5 speed gas or diesel trucks. Yards are full of them. Quote Link to comment
