AuosGnaf Posted June 30, 2012 Report Share Posted June 30, 2012 This is the only issue that's holding back my 510 to be able to be on the streets, again. I've check all the simple possible issues like fuse, bulb, and connection and now I'm at a lost! Here's the weird thing....it works off and on but that's not good enough for the brake and lamp inspector. I'm 99% done with all the necessary things for my 510 to be legal and this is the 1% that's kicking my butt. Any help will do. Thanks, S. Quote Link to comment
inline4 Posted June 30, 2012 Report Share Posted June 30, 2012 I'll be down in SD next week to stare at your 510 :D Quote Link to comment
inline4 Posted June 30, 2012 Report Share Posted June 30, 2012 there's a parking light indicator? I can jerry rig something for you when I'm down there. Quote Link to comment
AuosGnaf Posted June 30, 2012 Author Report Share Posted June 30, 2012 If I can't figure something out by tomorrow then that would be cool. Yeah, there's a parking brake light indicator on the cluster. There's a switch on the back of the parking brake unit and it looks fine and connected but some reason the light indicator works off and on. Quote Link to comment
inline4 Posted June 30, 2012 Report Share Posted June 30, 2012 oh, parking brake. just rig something up. Quote Link to comment
ggzilla Posted July 1, 2012 Report Share Posted July 1, 2012 How do you mean it "works off and on"? What does that mean? Quote Link to comment
AuosGnaf Posted July 1, 2012 Author Report Share Posted July 1, 2012 How do you mean it "works off and on"? What does that mean? Meaning when the parking brake is engaged some times it will light up and some times it won't. Quote Link to comment
ggzilla Posted July 1, 2012 Report Share Posted July 1, 2012 it stands to reason, then, that the problem is with the switch or how the switch is mounted. Quote Link to comment
AuosGnaf Posted July 1, 2012 Author Report Share Posted July 1, 2012 it stands to reason, then, that the problem is with the switch or how the switch is mounted. Well as you know the switch is a spring loaded momentary switch with just one wire. It's not disconnected or messed with in any way. The mounting I would assume it's fine because when releasing the parking brake it's in the correct position for contact to/with the switch. From the looks of everything it's fine....that's why I don't get why it's not lighting up. Quote Link to comment
ggzilla Posted July 1, 2012 Report Share Posted July 1, 2012 Because you are assuming it can't be the switch, you cannot understand. Yes. Sometimes switches work fine when triggered by hand, but bolted in place the switch is not moved as far, or in exactly the same direction. Quote Link to comment
AuosGnaf Posted July 1, 2012 Author Report Share Posted July 1, 2012 I have no idea what you mean by "not moved as far, or in exactly the same direction." Quote Link to comment
banzai510(hainz) Posted July 1, 2012 Report Share Posted July 1, 2012 People inspect things Like this.??????????YOu need a lamp to work to get the car on the road? Do as GGzilla says and youll figure out how ez it really is. Some times I reseat the connector on the instrument panel also in case there slight corrosion Quote Link to comment
AuosGnaf Posted July 2, 2012 Author Report Share Posted July 2, 2012 It's fixed and yes people inspect things like this. It's pretty much required in all states if you are trying to revive any automobile. I'm sorry, but GGzilla made no sense to me, but it doesn't matter because it's fixed now and over with. Quote Link to comment
ggzilla Posted July 2, 2012 Report Share Posted July 2, 2012 What was the problem? By the way, Oregon and Washington don't have safety inspections. Quote Link to comment
AuosGnaf Posted July 2, 2012 Author Report Share Posted July 2, 2012 There was a good amount of rust on the back of the switch and the surrounding ground area. Fcuking unbelievable how the previous owner just ignored the car and gave me all these little headaches (that's a whole other topic by itself). Anyways, cleaned off all the rust and the sand papered the mount/ground area down to the metal for better ground contact and now it's good. Waited 3 hours at the DMV for my number to be called and then less then 5 minutes for my plates and registration to be handed over. Lastly, all I have to do know is add the wagon to my insurance and DONE. Word to the wise: Don't buy a car from a dumb ass who thinks it's cool to fcuk things up due to their lack of appreciation of the car. Failed HID attempt and bolting the front seats to the floor board = punch to the face. Quote Link to comment
ggzilla Posted July 3, 2012 Report Share Posted July 3, 2012 Good work on finding the problem. Quote Link to comment
